Import json tags generating out of bounds for length
I want to use the interactive tag import function because I find it really cool.
But I've come across an error that I don't understand and I'd like to know if any of you can help me out.
Here are the elements:
First test: Import the tagD1.json file => Perfect !
tagD1.json (1.0 KB)
Second test: Import the tagD2.json
tagD2.json (1.0 KB)
Get the error
2023-09-19_14h18_44
The 6 depends on where I'm trying to create the tags. If I try to create folder on the root, I will get the same error but with Index 5 instead of 6:
2023-09-19_14h19_20
I thought that it may coming from a too long property on the tag definition but I do not see. It's propably something on the json file that it generated by an external tool but I do not see the issue....
Thanks,
Martial
You may find this of interest.
Thx Jordan,
Interested.
But tagD1.json was imported properly even with {é} and {-} on tagName
So ...
At the end, effectively, the issue was on the name of the folder that contains a . on G.E
Thanks Jordan for this orientation... I did not deeply dig about it enough.
You may also want to consider trimming/commonizing folder and tag names. A lot of terms are getting repeated. It's okay for the documentation properties, but the full tag paths stretch off into the horizon. :wink:
An example may be:
Armoire test/TGBT2/Tension Arrivée/QPT-IS1/Position
Armoire test/TGBT2/Tension Arrivée/QPT-IS1/Defaut
Jordan,
Thanks but I don't really understand what you mean...
You suggest to me to not use Tree organisation but better using long name with /, isn't it?
Thx
Tree organization is fine. I'm suggesting that extending the tree may help better group your tags.
Armoire test
    └ TGBT2
		└ Tension Arrivée
			└ QPT-IS1
				├ Position
				└ Defaut
I don't think '/' is a valid character in tag names.
He's suggesting reorganizing your tree so that things are logically grouped.
