Import Library 3rd Party Java or Python
Hi Everybody,
i developer aplication scada and i need funtionality for make calls with asterisk, then i try to join library java and python that would allow me in theory make the work via REST, in this case Java-asterisk and ari-py but no working, i locate this library according to the manual …
any idea? help me please
It sounds like you need to create an add-on module in java. You would start with the SDK. I would recommend starting with something simple (like learning the sample projects) before tackling a complex task like asterisk support.
