Import Socket error
I keep getting this error when running my FTP script.
ImportError: Error loading module FTP: Traceback(most recent call last):
File "C:\Program Files\Inductive Automation\Ignition\user-lib\pylib\ftplib.py", line 47 in import socket
File "C:\Program Files\Inductive Automation\Ignition\user-lib\pylib\socket.py", line 3 in from _socket import(File "C:\Program Files\Inductive Automation\Ignition\user-lib\pylib_socket.py", line 2, in import encodings.idna
ImportError:No module named idna
See if you have a copy of idna.py in C:\Program Files\Inductive Automation\Ignition\user-lib\pylib\encodings\.
yes we have that file in that folder
Did you ever manage to find a solution?
I am trying to import socket on a tag event script and it is doing the same thing...
([default]Test/Client/Command, valueChanged) Error executing tag event script: Traceback (most recent call last): File "tagevent:valueChanged", line 2, in valueChanged File "C:\Program Files\Inductive Automation\Ignition\user-lib\pylib\socket.py", line 3, in from _socket import ( File "C:\Program Files\Inductive Automation\Ignition\user-lib\pylib_socket.py", line 2, in import encodings.idna ImportError: No module named idna
I too have that file in that folder
This is the sort of trouble that makes me recommend never using python stdlib networking in jython. Use java sockets.
Gotcha, is this a python problem or an Ignition problem?
It works fine on a vision button press event script just not the tag event script…
Interestingly it works on a gateway tag change script!
