When I try to import a window in designer…I right click on an existing window and get the drop down menu. I click on import window and it looks for *.fwin files…when I locate the file I want to import I click on it and the screen refreshes but I don’t see the imported window. What am I doing wrong?
Terry,
If what you’re observing is similar to what I experience, the import dialog is covered by the main FPMI designer window. Try pressing one or more times to give the import dialog the focus.
I don’t understand why it happens but some thing similar happens when I open an app module for editing or when I open the Interactive Script Tester.
Not sure if this is it, but the window isn’t opened after its imported. It just shows up in the window list. Is this what you’re describing?
