Hello,
I am receiving this error:
File “event:propertyChange”, line 2, in
File “”, line 8, in check
ImportError: No module named shared
at org.python.core.Py.ImportError(Py.java:304)
at org.python.core.imp.import_first(imp.java:755)
at org.python.core.imp.import_module_level(imp.java:837)
at org.python.core.imp.importName(imp.java:917)
at org.python.core.ImportFunction.__call__(__builtin__.java:1220)
at org.python.core.PyObject.__call__(PyObject.java:357)
at org.python.core.__builtin__.__import__(__builtin__.java:1173)
at org.python.core.imp.importOneAs(imp.java:954)
at org.python.pycode._pyx2849.check$1(<custom-function check>:25)
at org.python.pycode._pyx2849.call_function(<custom-function check>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:134)
at org.python.core.PyFunction.__call__(PyFunction.java:317)
at org.python.core.PyMethod.__call__(PyMethod.java:109)
at org.python.pycode._pyx2848.f$0(<event:propertyChange>:2)
at org.python.pycode._pyx2848.call_function(<event:propertyChange>)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:636)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:180)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.access$000(ActionAdapter.java:40)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter$ActionRunner.run(ActionAdapter.java:286)
at java.desktop/java.awt.EventQueue.access$500(Unknown Source)
at java.desktop/java.awt.EventQueue$3.run(Unknown Source)
Ignition v7.9.13 (b2019120915)
Java: Azul Systems, Inc. 9.0.7.4
on a custom template with a propertyChange event handler:
and the custom method “check” is failing on the following line:
import shared.Util.Validate as validate
Any help is greatly appreciated.
Jesse
