I just added the Vision demo from the exchange. I added the application and ran it. When I connected to it via the client the images aren’t showing up. Do I need to import the images directory somehow?Screenshot
Yes, if you only imported a project you will need to import the image library as well.
Might be easiest to just restore the gateway, I believe they have the demo gateway backway available.
I downloaded the “Ignition 8.1 demo projects 3.0.0” zip file from the exchange. I unzipped then I imported Globalproject.zip (project), perspectivedemo.zip (project), and the visiondemo.zip (project) in designer (Screenshot). I then opened the vision client launcher and pointed it to my application gateway (localhost).
How do I restore a gateway as opposed to a project? Is there any way to import the image directory into the projects?
Nevermind, I figured out how to restore the gateway. Thanks.
For future reference, if needed…
https://docs.inductiveautomation.com/display/DOC81/Image+Management+Tool
Of course, you will need the images to import.
So, I restored the gateway and this of course blew out my existing gateway (I backed it up). But the trial expired. I found the username/password to the demo gateway but I’m not getting a prompt to enter it to then reset the trial.
How can I either:
Restore my old gateway (without being able to get into the gateway first)
Get a prompt to input username/password?
Press launch gateway to get you to the gateway launch pad.
If you want to restore a gatewua backup without the website, you can use the gwcmd utility Gateway Command-line Utility - gwcmd - Ignition User Manual 8.1 - Ignition Documentation
I pressed “Launch Gateway” and I just got a new tab of the same page.
I just reinstalled Ignition and am back running.
I ran into this issue myself. If you navigate to
IP:8088/web/config/
It will bypass the demo perspective app and will take you to your gateway home page. Then you can go to Config -> Gateway Settings -> Homepage Redirect URL and change that back to /web/home and once you save and reload the gateway it will no longer automatically bring you to your Perspective application.
