I have some data out on a PC controlled process that I would like to get access to in ignition for everything from viewing recent test results to archiving results using a transaction This system is an MTS elastomeric test stand. This data is not available in any kind of database on the PC and it is proprietary in every way, except the excel file it adds a section to every time a part is tested. I can possibly map a network drive to the data file location so I can have real time read only access to the excel file. Is anyone aware of how to get this kind of data into ignition?
if it is csv it should be pretty easy. if it is in xls or xlsx maybe check out the modules on the store. I havent tried but they are supposed to have some kind of support for reading excel files.
ssilk76
I’ve used the PA Office Document Module (other modules are available) to read and write cells in Spreadsheet
Here the link
http://marketplace.inductiveautomation.com/moduledetail?2&moduleId=89
Thank you for the info, I’ll have to take a look at the marketplace application
The PA Office Document Module can be found here now: perfectabstractions.com/products.html
Best,
