Hi Guys,
I’m new to Ignition. I noticed when running the code directly inside the script console. My script is working fine. Below is my sample script:
import xml.etree.cElementTree as ET
#Build the XML and return element for further processing
InSite = ET.Element(’__InSite’)
InSite.set(’__encryption’,‘2’)
print str(InSite)
In this sample snippet this works fine. However when I incorporate this code inside the Web Dev Module (WebService) my print str(InSite) is null. I think the import xml.etree.cElementTree as ET is culprit here. Is importing not allowed in Web Dev Module? Any suggestions?
Thanks.
