Ok so getting frustrated. I have done several Ignition projects in the past with no real issue. However, when I go to import or create new UDTs in the last 2 revision it does not appear that my OPC item Path is working. However, if I click edit and commit on the binding property for the item path (without changing anything in the editor) the OPC item path greys out in the UDT and the tag begins working. What the “Heck”, is this a bug and if so, does anyone know how far back in revs I have to go to get rid of it. I have UDTs with multiple tags in them and it makes no sense to use them if I have to go through and click on every last tag.
Sounds like a bug worth reporting to support. (This forum is not support.)
