When I do to paste the resource.json, thumbnail.png, and view.json, I get this error. I want to update this folder with an updated object. I have stopped the ignition gateway service yet am still getting this error. Is there anything else I need to do to add in this file?
Your Windows user is being prevented from moving anything into the program files directory. Not an Ignition thing; it's Windows trying to save you from yourself.
If you open the files you want to modify in a text editor that's running as administrator you should be able to save into the appropriate directory. I've forgotten if there's an easy way to get explorer itself to let you drag and drop as admin.
