I had created several bit reads and that works fine until the update to version 7.3.1
Before the update the “OPC item path” looks like this: [PLC22]L401203.6, after the update the “OPC item path” must be now like this : [PLC22]22.L401203.6 So I fix several tags so that it will work for the new version.
The value of a normal (not bitwise) holding register will be read perfect in the new version.
But reading a bit will not work. When I check the Tag Diagnostics I get the message “Unknown”.
After a few days when I check again with tag Diagnostics then is the message; “Stale”.
I use Modbus Driver v2 2.3.1 (b159)
Is there is something changed with the bit reading in this new version ?
