I don't know how to bring the axis label to the centre of the axis
Is there any property available?
Any possibility to make label centre?
here is the solution
i am trying to add "text-anchor": "middle",
"translate": "0px 45%" through scripting but its not adding
my code
item_dict = self.props.axes[len(self.props.axes)-1]
if 'label' in item_dict:
system.perspective.print('ssss..')
# Check if 'style' is present in the 'label' dictionary
label = item_dict['label']
if 'style' in label:
# If 'style' is present, update it directly
label['style']['text-anchor'] = "middle"
label['style']['translate'] = "0px 45%"
else:
# If 'style' is not present, create it and add the desired attributes
label['style'] = {
my axes json
<ObjectWrapper>: {u'color': u'#757A7F', u'dataFormat': u'0,0.##', u'grid': {u'visible': False, u'color': u'#757A7F', u'style': {u'classes': u''}, u'opacity': 0.9, u'dashArray': 0L}, u'name': u'Axis 6', u'width': 60L, u'range': {u'auto': True, u'min': u'', u'max': u''}, u'style': {u'classes': u''}, u'label': {u'offset': 0L, u'style': {u'classes': u''}, u'text': u'rammmm', u'font': {u'color': u'#757A7F', u'size': 10L}}, u'tick': {u'color': u'#757A7F', u'count': u'Auto', u'style': {u'classes': u''}, u'label': {u'format': u'Auto', u'style': {u'classes': u''}, u'font': {u'color': u'#757A7F', u'size': 10L}}}, u'position': u'left'}
can you please correct what i am doing wrong here please
component is XY chart- text-anchor property is not available for this component
you made the dict but did not assign it to the property
you will have to do something like this somewhere on the bottom of your if
(this not tested code)
self.props.axes[len(self.props.axes)-1]['label'] = label
not sure why you use scripting though, if you want to do this on all the axes, you should propably use the css class way, mentioned a bit lower in the post
yes they add new axis to the chart. i need this text anchor properties also to be added that why i used script.
ok i will check the post
can you guide me how to update the css class, i am new to this topic
when user add axis in front end (live project) i need to pass style class to the new axis
this scripting method is not working
can you give me any idea
is the style not working?
and did you try this?
yes not working
item_dict = self.getSibling("PowerChart").props.axes[6]
else:
label['style'] = {
system.perspective.print(label)
self.getSibling("PowerChart").props.axes[6]['label'] = label
then you might have to asign the whole label or even all the axes
but you should rly do the css
Solution
self.getSibling("PowerChart").props.axes[len(self.props.axes)-1]['label']['style'] = {
"classes": "",
