Inaccurate Concurrent Edit/Overlapping Resource notification
Version: 8.1.32
I'm working to integrate SAP batch handling into a client's Ignition Projects. They have multiple projects on a single Gateway. I've created a script in each project named "SAP_Integration". What I'm seeing is if I have a designer open to the "SAP_Integration" script in 'ProjectA', and I open a designer for 'ProjectB', it will show the "Concurrent User" icon for the "SAP_Integration" script in the 'ProjectB' designer. If you open the script it will prompt you with the "Confirm Concurrent Edit?" dialog, and once opened it will list 1 overlapping resource, even though these should be 2 completely separate unrelated scripts that just share a name. I believe I have also encountered this with Vision Windows by the same name in isolated projects. Is this a known issue?
Likely bug:
