Include Designer Jar in Client Module
I want to include the “com.inductiveautomation.ignition.designer.gui.tools.ImageChooser” class in a client scoped scripting function. I’ve written some code to create my own ImageChooser class in the client. It compiles, but the script still only works in the designer. What do I need to do to make maven include this jar in the build output?
You can’t use anything in the designer scope in client-scoped code. You can’t distribute the designer’s jars into client scope with your module!
You’re going to have to try a different approach for what you’re trying to do.
Bummer. I figured that was the answer but it was worth a try!
