I’m still fairly new to Ignition, so apologies if I’m making some very basic mistakes.
I’m using system.tag.configure to create a large set of tags from a .csv file.
I’m finding sometimes it works quickly, sometimes it works very slowly, sometimes the interpreter hangs, sometimes it throws back an error, sometimes it will create 3 tags, then hang.
Can anyone help me understand what would cause the errors I’m seeing below?
When the script errors I’ll see messages telling me the connection to the gateway has been lost.
There are no errors in the Logs, but I’ll see that a thread has been blocked with the following info.
Thread [tag-provider-My_Tags] id=87, (BLOCKED)
app//com.inductiveautomation.ignition.gateway.tags.actors.factories.value.AbstractValueGeneratingActor.setListener(AbstractValueGeneratingActor.java:37)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.ExecutableTag.manageActor(ExecutableTag.java:231)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.ExecutableTag.configureActors(ExecutableTag.java:756)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.ExecutableTag.applyPropertyChangesToTag(ExecutableTag.java:605)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.BasicTagDefinition.managePropertyChanges(BasicTagDefinition.java:776)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.BasicTagDefinition.manageChangesFromPropModel(BasicTagDefinition.java:758)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.BasicTagDefinition$$Lambda$593/0x000000010063d840.accept(Unknown Source)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.TagPropertyModel.dispatchPropertiesChanged(TagPropertyModel.java:64)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.TagPropertyModel.onPropertiesChanged(TagPropertyModel.java:42)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.InheritedExecutableTag.onPathChanged(InheritedExecutableTag.java:75)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.FolderNode$$Lambda$2541/0x0000000100f5e440.accept(Unknown Source)
java.base@11.0.11/java.util.ArrayList.forEach(Unknown Source)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.FolderNode.onPathChanged(FolderNode.java:403)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.BasicTagDefinition.applyPropertyChangesToTag(BasicTagDefinition.java:799)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.BasicTagDefinition.startPropModel(BasicTagDefinition.java:472)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.BasicTagDefinition.activate(BasicTagDefinition.java:927)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.BasicTagDefinition.startupInternal(BasicTagDefinition.java:911)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.MemberTagDefinition.startupInternal(MemberTagDefinition.java:84)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.BasicTagDefinition.startup(BasicTagDefinition.java:897)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.FolderNode.startup(FolderNode.java:293)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.AbstractTopLevelUdtTag.configureChild(AbstractTopLevelUdtTag.java:442)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.AbstractTopLevelUdtTag.manageMemberChanges(AbstractTopLevelUdtTag.java:261)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.AbstractTopLevelUdtTag.onSuperMembersChanged(AbstractTopLevelUdtTag.java:175)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.TypesFolder$AbstractTypeNode.onSuperMembersChanged(TypesFolder.java:525)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.TypesFolder$AbstractTypeNode.onValidityChanged(TypesFolder.java:472)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.TypesFolder$AbstractTypeNode.setValidityState(TypesFolder.java:450)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.TypesFolder$AbstractTypeNode.refreshValidity(TypesFolder.java:373)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.TypesFolder$AbstractTypeNode.setSuperType(TypesFolder.java:312)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.TypesFolder$AbstractTypeNode.notifyParentTypeChanged(TypesFolder.java:290)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.TypesFolder$AbstractTypeNode.attach(TypesFolder.java:282)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.TypesFolder.registerComplexNode(TypesFolder.java:112)
app//com.inductiveautomation.ignition.gateway.tags.runtime.nodes.complex.AbstractComplexTagDefinitionNode.startupInternal(AbstractComplexTagDefinitionNode.java:118)
app//com.inductiveautomation.ignition.gateway.tags.runtime.TagEvaluationManagerImpl.processNewTag(TagEvaluationManagerImpl.java:546)
app//com.inductiveautomation.ignition.gateway.tags.runtime.TagEvaluationManagerImpl.processEditInternal(TagEvaluationManagerImpl.java:385)
app//com.inductiveautomation.ignition.gateway.tags.runtime.TagEvaluationManagerImpl.processEdit(TagEvaluationManagerImpl.java:299)
app//com.inductiveautomation.ignition.gateway.tags.TagProviderImpl.saveTagConfigInternal(TagProviderImpl.java:758)
app//com.inductiveautomation.ignition.gateway.tags.TagProviderImpl.lambda$saveTagConfigsAsync$11(TagProviderImpl.java:715)
app//com.inductiveautomation.ignition.gateway.tags.TagProviderImpl$$Lambda$2543/0x0000000100f5dc40.get(Unknown Source)
app//com.inductiveautomation.ignition.gateway.tags.TagProviderImpl.lambda$exec$3(TagProviderImpl.java:437)
app//com.inductiveautomation.ignition.gateway.tags.TagProviderImpl$$Lambda$2544/0x0000000100f5d040.get(Unknown Source)
java.base@11.0.11/java.util.concurrent.CompletableFuture$AsyncSupply.run(Unknown Source)
java.base@11.0.11/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
java.base@11.0.11/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.base@11.0.11/java.lang.Thread.run(Unknown Source)
The error thrown back to me from the interpreter is:
Java Traceback:
File "<input>", line 104, in <module>
File "<input>", line 13, in openFile
File "<input>", line 100, in addUDT
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:543)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:283)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:945)
at com.inductiveautomation.ignition.client.script.ClientTagUtilities.saveTagConfigs(ClientTagUtilities.java:105)
at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.configure(AbstractTagUtilities.java:199)
at jdk.internal.reflect.GeneratedMethodAccessor43.invoke(Unknown Source)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
at org.python.core.Py.JavaError(Py.java:547)
at com.inductiveautomation.ignition.client.script.ClientTagUtilities.saveTagConfigs(ClientTagUtilities.java:108)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:546)
at org.python.core.PyObject.__call__(PyObject.java:494)
at org.python.core.PyObject.__call__(PyObject.java:498)
at org.python.pycode._pyx46.addUDT$2(<input>:102)
at org.python.pycode._pyx46.call_function(<input>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:134)
at org.python.core.PyFunction.__call__(PyFunction.java:416)
at org.python.pycode._pyx46.openFile$1(<input>:12)
at org.python.core.PyBaseCode.call(PyBaseCode.java:119)
at org.python.core.PyFunction.__call__(PyFunction.java:406)
at org.python.pycode._pyx46.f$0(<input>:104)
at org.python.core.Py.runCode(Py.java:1687)
at org.python.core.Py.exec(Py.java:1731)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:605)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:593)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
... 34 more
Caused by: java.net.SocketTimeoutException: Read timed out
at java.base/java.net.SocketInputStream.socketRead0(Native Method)
at java.base/java.net.SocketInputStream.socketRead(Unknown Source)
at java.base/java.net.SocketInputStream.read(Unknown Source)
at java.base/java.io.BufferedInputStream.fill(Unknown Source)
at java.base/java.io.BufferedInputStream.read1(Unknown Source)
at java.base/java.io.BufferedInputStream.read(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.base/java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:437)
... 38 more
