Not sure if this is a bug or not: when a request to a remote gateway times out, the exceptions that are raised are inconsistent.
Most of the time a com.inductiveautomation.metro.api.ex.TimeoutExpiredException is thrown
Java Exception: <type 'com.inductiveautomation.metro.api.ex.TimeoutExpiredException'>
TimeoutExpiredException[queueId=scriptMsgQueue, targetIntent=PLATFORM_SCRIPT_REQ, msgData=com.inductiveautomation.ignition.gateway.clientcomm.scriptmsg.RemoteScriptMsg@7146e0f]
but occasionally a java.util.concurrent.TimeoutException is thrown instead, using the exact same request.
Java Exception: <type 'java.util.concurrent.TimeoutException'>
java.util.concurrent.TimeoutException: Timeout has expired for sendRequest operation
This makes it quite annoying to consistently and unambiguously catch a timeout exception (which is normally a transient error).
My test setup consists of a bare perspective view, containing only a TextArea and a OneShotButton. The onActionPerformed code for the button is below.
Code
out = self.getSibling("TextArea")
out.props.text = "Busy ..."
import java.lang.Throwable
_remoteServer = "OT01"
_project = "Redacted"
_messageHandler = "Product"
_timeoutSec = 2
payload = {"action": "getById", "id": '784a4eca-1383-41b1-affb-b862356ed269'}
try:
response = system.util.sendRequest(_project, _messageHandler, payload, _remoteServer, _timeoutSec)
out.props.text = repr(response)
except java.lang.Throwable as t:
out.props.text = "Java Exception: {}\n{}".format(t.getClass(), repr(t))
except Exception as e:
out.props.text = "Python Error: {}\n{}".format(e.__name__, repr(e))
finally:
self.props.value = 0
We're running Ignition 8.1.36 on Windows Server 2019. The "OT01" gateway connection is configured in the settings, but is disabled to simulate this error.
