A known issue as of now is if you try to bind the cluster address to a bad address. You would do this in the Gateway Configuration page->Network and
- Unchecking Autodetect Bind Interface
- Typing a bad address under Bind Interface
The FactoryPMI service will not start. If you look in the “Monitor FPMI Gateway” utility you will see the following error:
Error connecting to cluster. failed to start protocol stack
The fix is to go into the cluster.xml file and change this line from false to true.
<entry key="cluster.bind_addr.autodetect">true</entry>
We’re currently investigating the best way to fix the problem and prevent it from occurring. It may include a cluster reset option in the “Monitor FPMI Gateway” utility.
