I’m looking at a project that was developed in 8.1.? where the OPC tag addresses use ‘nsu=urn:inductiveautomation:ignition:opcua:tags;s=’ in the OPC path.
Should this work, or has this been phased out / changed in a newer version of Ignition 8.1.X where only index-based namespace will work? ‘ns1;s=’?
When trying to read from these tags in the designer I get a configuration error: Bad(“Bad_NodeIdUnknown: The node id refers to a node that does not exist in the server address space.”)
I’m trying to work out if I need to update all the OPC addresses, or if there is some additional configuration i’m not aware of?
What you’re seeing is a tag added to that gateway that came from the Exposed Tags feature. If it was from the same gateway that was probably a mistake, but if it was from another gateway that’s probably okay.
When tags are brought in from the OPC Browser to the Tag Browser the the full namespace URI is used any time the index is 2+, regardless of the server.
In the Ignition OPC UA server the tags exposed by the Exposed Tags feature reside at namespace index 2.
