I’m trying to get the position of a caracter in a sting
substring({Obj_DI_Square.DeviceTag::ID},indexOf({Obj_DI_Square.DeviceTag::ID}, “.”),len({Obj_DI_Square.DeviceTag::ID}))
And the indexOf({Obj_DI_Square.DeviceTag::ID}, “.”) is causing a error
java.lang.Exception: Error executing expression binding on
Obj_DI_Square.Obj_DI_Square.lab_objectID.text
Any Idea?
Can you post the full stack trace of the error? On the error dialog, click ‘Full’, then copy the full text and paste it in here.
As a preliminary guess - is the ID tag actually a string, or is it a numeric type (integer, float, etc)?
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:91)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.startup(ExpressionPropertyAdapter.java:112)
at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.setPropertyAdapter(DefaultInteractionController.java:207)
at com.inductiveautomation.factorypmi.designer.property.configurators.ExpressionConfigurator.bind(ExpressionConfigurator.java:283)
at com.inductiveautomation.factorypmi.designer.property.configurators.ExpressionConfigurator.tryCommit(ExpressionConfigurator.java:219)
at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor$EditorParent.tryCommit(ConfiguratorMultiplexor.java:213)
at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor.tryCommit(ConfiguratorMultiplexor.java:358)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.doOK(DynamicOptsDialog.java:117)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.access$000(DynamicOptsDialog.java:43)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog$1.actionPerformed(DynamicOptsDialog.java:83)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.WaitDispatchSupport$2.run(Unknown Source)
at java.awt.WaitDispatchSupport$4.run(Unknown Source)
at java.awt.WaitDispatchSupport.enter(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.showDialog(DynamicOptsDialog.java:185)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.openBindingDialog(VisionDesignerImpl.java:1119)
at com.inductiveautomation.vision.api.designer.beans.InPlaceEditHandler.onDoubleClick(InPlaceEditHandler.java:58)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.handleDoubleClick(WindowWorkspace.java:813)
at com.inductiveautomation.ignition.designer.designable.tools.SelectionTool.onDoubleClick(SelectionTool.java:552)
at com.inductiveautomation.ignition.designer.designable.DesignPanel$ToolMouseListener.onClick(DesignPanel.java:998)
at com.inductiveautomation.ignition.client.util.gui.CommonMouseAdapter.mouseReleased(CommonMouseAdapter.java:69)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
Caused by: java.lang.NullPointerException
at com.inductiveautomation.ignition.common.expressions.DefaultFunctionFactory$IndexOfFunction.execute(DefaultFunctionFactory.java:558)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.execute(FunctionExpression.java:69)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:82)
… 94 more
Ignition v7.9.1 (b2017012511)
Java: Oracle Corporation 1.8.0_102
i have been able to get around by
try(substring({Obj_DI_Square.DeviceTag::ID},indexOf({Obj_DI_Square.DeviceTag::ID}, “.”)+1,len({Obj_DI_Square.DeviceTag::ID})),“ERR”)
But i’m curious why i got that error
