I want to address a tag within a tag using both an expression and by creating a new OPC Tag.
I have a tag with the following path:
CMP2VC/EditRecipe/Step/Step_1_/TimeEnable
I want to make the value of 1 in the above path dynamic. I have another tag that it should be referring to for obtaining that value. For example,
CMP2VC/EditRecipe/Step/Step_[EditRecipeStepIndex]_/TimeEnable
The EditRecipeStepIndex outputs an integer value and I want the tag to refer to that value.
I have tried it using two ways. One is through an expression and the other one through an OPC tag.
Neither worked!
Expression:
tag({CMP2VC/EditRecipe/Step/Step_}+"toInt({CMP2VC/EditRecipe/EditRecipeStepIndex})"+"_TimeEnable")
New OPC Tag:
In OPC Item Path
[CMP2VC]Global.EditRecipe.Step.Step[Global.EditRecipeStepIndex].TimeEnable
