Indirect binding to SQL tag row?
I have an SQL tag that returns a 5-lines, 10-columns dataset. One of the columns is “name”. Now I want to bind a text box to column “name” of a parametrized row, so I thought I could set a binding to [default]mytag.value[name][{1}] where {1} is the parametrized line number. However, I don’t seem to get any value. Am I doing something wrong?
You’ll have to use a tag reference within an expression binding instead. {[default]myTag}[{Root Container.rowIndex}, “name”] within an expression binding will return the cell’s value for the row index (custom prop) and “name” col.
Works, thanks. However, this has to be entered by hand, since using the guided tag/property selector in both the indirect tag binding and the expression binding leads to an expression of the form [default]mytag.value[name][{Root Container.rowIndex}]
