I have a scenario where using Indirect Tags would easily solve the programming of faceplates to show detailed information and configuration. I have the concern that the approach could not be the best in terms of data traffic, though.
Let me explain:
I have different datatypes that represent add-on objects that model analog inputs, motors, digital inputs, PIDs, etc. from a Logix controller. Each add-on is a complex structure that contains dozens of tags used for configuration and status. For display purposes I usually need about 4 to 5 tags used in a template to show the basic information. If I click on the template, a faceplate is opened and depending on the complexity of the object, several tags are used in animations, module configuration and alarms.
The problem I see is that since the additional information is only required when the faceplate is opened for the specific instance, if I use SQLTags to represent the whole structure, I am adding overhead to the communication because I am reading tags at a fixed rate from the controller that usually are not active in the display.
Is there a way to make an indirect tag reference but using OPC items instead? That would mean that instead of having a SQLTag under a datatype called ANALOG/AlarmHHEnable I can use a reference such as {Parameter}.AlarmHHEnable where {Parameter} is an OPC item.
The idea is only read the information that is not used frequently when is really required, instead of having regular updates for all the instances that probably won’t be used.
I guess I am asking if there is something similar in concept to SQLBridge OPC Items using Read OPC mode on triggered transactions: data is only retrieved when transaction is active. I would like to accomplish that but only when the tags for the specific instance are active.
I tried to figure out a way to do this using leased scan classes, but since the scan class is defined from the datatype, that would mean that all the instances of that datatype will be activated if there is at least one of the many activated. Or I would have to create as many leased Scan Classes as modules instances.
My other approach was to pass the OPCItemPath and create a script triggered by a timer to periodically update the values, but this requires more programming and have some complexity when used in cases where the control is bi-directional.
Any idea or suggestion
Thanks.
