Indirect Tag Binding Issue
Modified and imported a modified .csv file with added tags. The new tags are visible from the sql tag browser but not visible when trying to bind indirectly. ver 7.4.1.906. Also noticed that even without entry to the indirect tag path you still was able to exit the property binding editor and the property showed that it was bound. Seems like it shouldn’t do that if there’s a blank entry.
Found that I imported the modified csv into a sub folder instead of the route. all ok now
