Indirect tag binding on view param broken
Hi all,
I don't know if this is related to the recent update, but I am rebuilding a view with an indirect tag binding. The original works fine:
Binding is indirect on this tag:
[default]Machine Process/TMs/{1}_TM1/Enabled
param: {view.params.zoneKey}
Bidirectional
New build:
param: {view.params.zone} (I changed zoneKey to zone in the new build.)
Bidirectional
When I add the parameter and click OK, and reopen, the parameter is empty. The error, before and after clicking OK is: Error configuration: expression is empty.
Thoughts? Thanks in advance.
Edit: I even changed the binding parameter to view.custom.zone
And it's still empty when I reopen it.
When you change the property make sure you hit enter to confirm the change, otherwise it does not see it.
Doh! :man_facepalming:
I've been stymied by that a few times myself :slight_smile:
When you do something once, a year ago... lol
