Individual Components on XY View with Mode: Percent
Hi All:
I am just wondering if there is a way to set individual components to not stretch when you have a XY View setup in mode: percent? i.e have certain components setup at a fixed width/height while the rest scale? Or is this not possible?
Thank You
What you can do is set your Coordinate Container to fixed rather than percent. Then, for each component in that container, you can put in a percentage for its height/width/position properties as needed while leaving the other properties as pixel values if you don’t want it to stretch or move in that direction.
For example, this has a constant height and y-position while stretching horizontally as the view width increases:
Perfect - thank you.
