Project touches on a few things I have not done too much with before I normally work on standalones.
We a gateway with a EAM module, and are going to many plant gateways that connect to it. They will all be serving the same project with some plant speciifc considerations.
What is common-All scripts in my scripting library should ideally work for all plants or made to. 90% of windows are common. There's a handful that we know to be plant specific frightnow.
I am at a point where we have 2 plants done, not in any shared fashion outside of my personal ability ot keep things in sync and so now is the time to reconcile this as best I can to get to where there is cohesion.
My thinking was the EAM hosts the inheritable project and that is where I make any changes that affect all plants, and that is what I push. Then on each plant I inherit the project across the EAM and at the site is where I can make changes to the site specific windows.
From people with experience with this setup how would you do it?
So I followed a post by @pturmel at one point (with a little simplification) and use the following structure on each gateway (Usually only have Perspective or Vision but not both so the plant specific project depends on which type of system we're deploying):
- Universe (All master script libraries, views, windows, etc live here that are common standards)
- AlarmNotifications
- GatewayScripts (Gateway Scripting Project)
- Perspective-Common (Plant Specific Perspective Views/etc)
- (Project launched for production)
- Perspective-Dev (Development project for testing)
- Reports (Scheduled Gateway Reports)
- Vision-Common (Plant Specific Vision Windows/Templates/etc)
- Vision-Dev (Development project for testing)
This way you could replicate this structure on our EAM gateway as your master repository essentially and be able to push from there to all your EAM agents.
Great thank you! It is vision for what its worth don't think that changes anything here though, and version 8.1
So parent project
scripts
|--universe
Vision
|--common windows
|--common templates
reports
|--common reports
And my inheritable project would only be
Vision
|--plant specific windows
|--plant specific templates though I am trying to avoid this
And in my child project the only additional stuff I would need to do is tellign the gateway timers/tag change events etc to run my universe.gw.timer.somefunction() .
My last question would be how to manage UDT's if they are to be the same plant to plant? Anything regarding EAM or inheritable projects here that would assist here with keeping them in sync?
