Hello. What are you naming your inheritable projects. When I name them 'global' this messes with the word 'global' in the python scripting. Do you call your inheritable project 'shared' or any other name? When I work on a gateway for the first time I prefer to have one inheritable project and then my regular projects. Generally are you using the inheritable projects for your work or does it cause more problems then solutions.
I name the project Global and the project library shared.
My inheritable project is "zz_standards", which pushes it to the bottom of the list. In the project, wherever possible, all the items are in folders called "zz_standards" to make it obvious in other projects where it came from.
This is a takeoff of something I learned nearly 30 years ago. There, the "standards" folder was called "zz_top", the "zz" moved it to the bottom of the list and the company owner had a favorite band...
