Hello, I am setting up Ignition on a new work computer and I initially installed Designer Launcher first and then tried to install Ignition and it was giving me errors throughout the installation process.
I was told I might have installed them incorrectly since the gateway has a link to install the designer launcher that will automatically match the versions so that they are compatible.
Learning this, I uninstalled both and thought that I could install Ignition first and run the gateway then form there install designer launcher however now when I run the ignition-8.1.44-windows-64-installer.exe I get this error right at launch:
Any thoughts? Im not sure if there are lingering files left on the computer that didn't get full uninstalled or not but im not sure where to continue from here...
