I need to inner join two different tables from different database connections. How would I do this in a query from say “database1”?
SELECT
FROM
table1 t1
INNER JOIN
dbConn2.database2.table2 t2 ON t1.Field = t2.Field
SELECT
FROM
table1 t1
INNER JOIN
You cannot join using database connections.
If database2 is on the same server as database1, you can do this.
SELECT
FROM
table1 t1
INNER JOIN
They are on different servers but I got it figured out, thanks!
SELECT
FROM
table1 t1
INNER JOIN
[SeverName].Database2.dbo.Table2 t2 ON t1.Field = t2.Field
What is the proper syntax for referencing the server name?
