Hi to everybody
From this post seems the Input file register of the micrologix not supported from the driver of Ignition.
viewtopic.php?f=70&t=7714&p=23900&hilit=1400+00#p23900.
It’s still true? I’m having some strange behaviours. The driver seems to import correctly the input files, but when I try to read the[Micro 1400]I:1.0/0 ignition reads a null value.
Ignition seems able only read the I:0 files. But the strange thing is, If I defined a Sql Tags [Micro1400]I:0.1/00 , ignition reads the value of the bit of the PLC with the address I:1.0/0
I must moving all the input registers into the internal registers, Igniton does not support the directly addressing yet?
Thank you very much
Andrea
