Insert euro symbol in database from ignition
Hi guys,
I have tried to insert the euro(€) symbol in the database using the insert query from the vision button action performed but the format is not ok in the database.
val = str(202) + str("€")
Display the database in this format:
Database = SQL Server
Ignition = 8.1.17
when I directly insert it from the SQL server then worked perfectly. but When I tried to insert it from the ignition then not ok.
Any idea how to fix this?
Thanks,
Priyanka
don't use str(). That is not unicode-friendly. Use the u'' marker for jython string constants that need unicode treatment. So:
val = str(202) + u'€'
@pturmel Thank you so much for your quick response.
Worked perfectly!!
