Hello,
My table in SQL Server is setup not to allow NULL values. When using runPrepUpdate, if the text field I’m using is blank, runPrepUpdate inserts an empty string instead of using NULL. Is there a way to use NULL by default? I’d prefer to not have to check every field every time for blank strings.
Thanks!
Brian
