Insert query quarantined in Store and Forward but runs fine elsewhere
I’m trying to work out why some of my scripted system.db.runSFUpdate insert statements are ending up in the SF quarantine. I’ve exported the quarantine and looked at some of the failed queries in Kindling, then reconstructed some of the queries and run them in SSMS and they run fine. I’ve attempted to retry the quarantine to process the others that look like they should work as well, but the same number of quarantined items remains. I’m trying to work out why they’re not able to run :confused:
Example query viewed in Kindling (only showing the first VALUES block, but the rest are below:
Edit: the only unique constraint is on the auto-incrementing PK id field, so it’s not an issue with constraints (also demonstrated by the fact that the queries do run successfully in SSMS)
Edit2: I retried the quarantine and saw an error appear in the logs:
java.lang.RuntimeException: com.microsoft.sqlserver.jdbc.SQLServerException: Conversion failed when converting the nvarchar value 'Empty' to data type int.
at com.inductiveautomation.ignition.common.functional.FragileConsumer.lambda$wrap$1(FragileConsumer.java:47)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.base/java.util.stream.Streams$StreamBuilderImpl.forEachRemaining(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$Head.forEach(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$7$1.accept(Unknown Source)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.forEach(Unknown Source)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.storeToDatasource(AbstractDatasourceSink.java:189)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.storeData(AbstractDatasourceSink.java:156)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AggregateSink.storeData(AggregateSink.java:165)
at com.inductiveautomation.ignition.gateway.history.forwarders.ForwarderThread.run(ForwarderThread.java:147)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Conversion failed when converting the nvarchar value 'Empty' to data type int.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:265)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1695)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:620)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:539)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7685)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:4048)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:272)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:246)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeUpdate(SQLServerPreparedStatement.java:484)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:136)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeUpdate(SRConnectionWrapper.java:981)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runPrepUpdate(SRConnectionWrapper.java:181)
at com.inductiveautomation.ignition.gateway.script.ialabs.IALabsDatasourceFunctions$QuerySFData.storeToConnection(IALabsDatasourceFunctions.java:318)
at com.inductiveautomation.ignition.gateway.history.sinks.RecordDatasourceSink.storeDataToDatasource(RecordDatasourceSink.java:41)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.lambda$storeToDatasource$3(AbstractDatasourceSink.java:189)
at com.inductiveautomation.ignition.common.functional.FragileConsumer.lambda$wrap$1(FragileConsumer.java:45)
... 16 common frames omitted
How is the quarantine processed, specifically I assumed that any individual query errors would not affect the running of the other queries?
I would look for a data type casting error in your Python script. Looks like you have a null value coming in as a string that needs to be explicitly cast to an int.
There are actually 1041 quarantined insert queries in the quarantine file; this one in particular I know the cause of, but for the queries in there that are valid and do execute in SSMS for example, I want to know:
  1. why they were included in the quarantine, and
  2. why retrying the file seemingly doesn’t run through the other queries in the file (it stops if there's an error in any of them - I don't know the full context of this without testing more)
My thought was SSMS may handle type casting issues better than Ignition.
I'm gonna guess there are nulls involved, and the standard query thereby becomes ambiguous.
I don't know that that's true, actually. Basically it depends on the 'flavor' of the data (and some other factors). That's something that got hopefully less opaque in the refactor in 8.3. There's some weird one to many calculations for "record counts" in S+F.
Which specific 8.1 version was this? I feel like at some point fairly late in 8.1 there was a change addressing this kind of thing specifically.
We only upgraded recently for a memory leak bugfix (affecting remote tag providers), so it’s at 8.1.51 at the moment.
I’m about to try to run one of the queries from the script console instead of via SSMS. I’ll see if they still fail
