Insert Results of Named Query to Text Field
Hello all,
I think this one should be easy but I'm a bit stumped.
I need to use a button to fire a named query which will return only one result and insert that result into a text field. I do not want to bind the text property of the text field to the named query because I want to control when it runs, which is why I am adding the script to the button.
Here is the query:
SELECT cartID
FROM CommTrackCarts
WHERE   startBuild = (
	SELECT MAX(startBuild) FROM CommTrackCarts
	WHERE cartNumber =  :cartNumberParam )
And here is the script inside of my button:
params = {
	"cartNumberParam": event.source.parent.getComponent('Cart').text
system.db.runNamedQuery("INSERT Cart", params)
event.source.parent.getComponent('CartID').text = str(system.db.runNamedQuery("SELECT MAX", params))
Right now, this places the dataset into the text field and I need it to return a specific item from the dataset:
Any and all help is greatly appreciated!
In the named query, change the query type to scalar. This will prompt it to return a single value instead of a dataset.
Fantastic!
Did not know what a scalar query did, but that was exactly what I needed. Thanks so much for the feedback. Such an easy fix! :smile:
scalar
/ˈskeɪlə/
Mathematics•Physics
adjective
  1. (of a quantity) having only magnitude, not direction. [A regular SQL query would have two dimensions; rows and columns.]
noun
  1. a scalar quantity.
