Is there any way to insert history data manually in tables sqlt?
Ignition version 7.6.3
Regards
Regards
Is simply opening the table in a database management program like SQL management studio or PHP admin and put the values not an option?
While going through your DB management software would probably be the easier solution, there’s also the system.tag.storeTagHistory function that could work for whatever you’re trying to do.
