here is the transform I currently have on it where I am appending a column on to the table:
table = self.getSibling("Table_0").props.data
accounted_badge_num = [B['Badge_Num'] for B in table]
json_obj = []
for V in value:
py_dic = {"value":dict(V)}
if py_dic["value"]['BadgeNum'] in accounted_badge_num:
py_dic["value"]['isAccountedFor'] = True
py_dic["style"]={"backgroundColor":"green"}
else:
py_dic["value"]['isAccountedFor'] = False
json_obj.append(py_dic)
return json_obj
SELECT
VP.PERSONNUM AS 'BadgeNum'
, FORMAT( VP.INPUNCHDTM, 'hh:mm') AS 'ClockINTime'
, VP.PERSONFULLNAME AS 'Name'
, HOMELABORLEVELNM5 AS 'Shift'
, HOMELABORLEVELNM6 AS 'Dept'
, HOMELABORLEVELDSC7 AS 'JobTitle'
, HOMELABORLEVELDSC4 AS 'Supervisor'
FROM
VP_EMPCUREARNTIME AS VP
LEFT OUTER JOIN VP_EMPLOYEEV42 ON VP.PERSONNUM = VP_EMPLOYEEV42.PERSONNUM
LEFT OUTER JOIN TIMEZONE ON VP_EMPLOYEEV42.TIMEZONENAME = TIMEZONE.ENGLISH
WHERE
(VP.LABORLEVELNAME3 = '0065')
AND VP.INPUNCHDTM is not Null
AND VP.LABORLEVELNAME5 NOT IN ('9', 'S')
AND (VP.STARTDTM > DATEADD(d, - 1, GETDATE()))
AND (VP.GMTSTARTDTM <= DATEADD(S, - TIMEZONE.GMTOFFSET, GETDATE()))
AND (VP.GMTENDDTM IS NULL OR VP.GMTENDDTM >= DATEADD(S, - TIMEZONE.GMTOFFSET, GETDATE()))
order by HOMELABORLEVELNM6, HOMELABORLEVELDSC7
When I try and INSERt it tells me that I cant due to effecting other data sources
I was just informed that I cannot mod the database that table was created form, I have READ access only.
Any ideas on how I can add rows via the current transform I am using?
json_obj = []
for V in value:
else:
return json_obj
Well if this is being pulled from a database, then updating just the table in perspective will not do you much good.
As soon as the binding is refreshed for any reason, any changes that have been made will be lost unless you somehow update the database table.
Note that ignition doesn’t run under your credentials but under those that the ignition service is using. So that user needs to have read and write access to the database.
