I am running the system.db.runPrepUpdate statement with the getKey=1 option and get an error if there is a $ in the text field I am writting to a varchar in the db. Here is the actual error details:
[quote]Traceback (innermost last):
File “event:actionPerformed”, line 350, in ?
java.lang.Exception: Error executing system.db.runPrepUpdate(Insert into dbo.tblComplaint (FirstName,LastName,MailingAddress,City,State,ZipCode,Phone,EMail,SalesContact,ConsumerStatement,ComplaintType,Consumer,VJC,Research,ResponseText,PRKYN,DateReceived,CheckAmt,PackageID,PackageType,PackageTypeDetail,PurchaseLocation,Injury,TreatmentRequired,ConsumerSatisified,BreweryAction,OI) Values (?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?), [Ron, Mayfield, 1075 East 20th St., Chico, CA, , , , , This is a test as the $ seems to be causing issues., Quality, 1, , , , No, 01/25/2012, 0.0, , Bottle, , , No, No, Yes, , No], , , true)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Unable to read response from Gateway.
Caused by: org.xml.sax.SAXParseException: The element type “ResponseWrapper” must be terminated by the matching end-tag “”.
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(Insert into dbo.tblComplaint (FirstName,LastName,MailingAddress,City,State,ZipCode,Phone,EMail,SalesContact,ConsumerStatement,ComplaintType,Consumer,VJC,Research,ResponseText,PRKYN,DateReceived,CheckAmt,PackageID,PackageType,PackageTypeDetail,PurchaseLocation,Injury,TreatmentRequired,ConsumerSatisified,BreweryAction,OI) Values (?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?), [Ron, Mayfield, 1075 East 20th St., Chico, CA, , , , , This is a test as the $ seems to be causing issues., Quality, 1, , , , No, 01/25/2012, 0.0, , Bottle, , , No, No, Yes, , No], , , true)
Ignition v7.3.3 (b570)
Java: Sun Microsystems Inc. 1.6.0_30
[/quote]
