Inserting the last row of a pydataset into a database table
Hi:
I want to insert the last row of a pydataset into an existing database. However, my current script adds the entire dataset each time it is executed. What modifications can I make to my script (below) to ensure only the last row of the dataset is inserted into the database table?
Script:
pydata = system.dataset.toPyDataSet(data)
strQuery = "INSERT INTO Results (t_stamp, serial_numbers, avg) VALUES (?,?, ?)"
for row in pydata:
	t_stamp = row["Time Stamp"]
	serial_numbers = row["Serial Numbers"]
	avg = row["Ave"]
	args = [t_stamp, serial_numbers, avg]
	system.db.runPrepUpdate(strQuery, args)
Additional Information: To avoid DUPLICATE KEY errors, I removed the PRIMARY KEY from my serial_number column. I would like to have a PRIMARY KEY column either with an AUTO-INCREMENT INDEX or my serial_number column.
Thank you.
Hi! Welcome to the forum. :slight_smile:
The quickest change would be to move the runPrepUpdate out of the loop:
for row in pydata:
	avg = row["Ave"]
A bit shorter version.
lastRow = pydata[len(pydata)-1]
t_stamp = lastRow["Time Stamp"]
serial_numbers = lastRow["Serial Numbers"]
avg = lastRow["Ave"]
system.db.runPrepUpdate(strQuery,  [t_stamp, serial_numbers, avg])
Last one. I promise!
To answer your other question that I quite overlooked about adding a primary key column, (I’m gonna assume MySQL, since you didn’t mention what you’re using.)
ALTER TABLE table_name ADD new_column int NOT NULL AUTO_INCREMENT primary key
Hi!
Thanks for welcoming me to the forum; much appreciated!
That’s exactly what I was looking for! Thanks!
