Install from intelliJ
since some weeks, I had some trouble with install execution of maven :
[INFO] Installing D:\dev\svn\LB9000\LB9000-build\target\LB9000-Driver-Module-unsigned.modl to gateway. [INFO] ------------------------------------------------------------------------ [INFO] Reactor Summary: [INFO] [INFO] LB9000 Driver Module ............................... SUCCESS [ 0.440 s] [INFO] LB9000-Gateway ..................................... SUCCESS [ 3.106 s] [INFO] LB9000-build ....................................... FAILURE [ 1.369 s] [INFO] ------------------------------------------------------------------------ [INFO] BUILD FAILURE [INFO] ------------------------------------------------------------------------ [INFO] Total time: 5.045 s [INFO] Finished at: 2017-04-03T18:49:42+02:00 [INFO] Final Memory: 17M/168M [INFO] ------------------------------------------------------------------------ [ERROR] Failed to execute goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.0.8:post (postexecution) on project LB9000-build: Could not post the module to the Gateway. Could not post module to gateway. no protocol: 127.0.0.1:8088/main/system/DeveloperModuleLoadingServlet -> [Help 1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.0.8:post (postexecution) on project LB9000-build: Could not post the module to the Gateway. at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80) at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288) at org.apache.maven.cli.MavenCli.main(MavenCli.java:199) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356) at org.codehaus.classworlds.Launcher.main(Launcher.java:47) Caused by: org.apache.maven.plugin.MojoExecutionException: Could not post the module to the Gateway. at com.inductiveautomation.ignitionsdk.PostModuleMojo.execute(PostModuleMojo.java:78) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207) ... 21 more Caused by: org.apache.maven.plugin.MojoExecutionException: Could not post module to gateway. at com.inductiveautomation.ignitionsdk.PostModuleMojo.postModuleToGateway(PostModuleMojo.java:119) at com.inductiveautomation.ignitionsdk.PostModuleMojo.execute(PostModuleMojo.java:75) ... 23 more Caused by: java.net.MalformedURLException: no protocol: 127.0.0.1:8088/main/system/DeveloperModuleLoadingServlet at java.net.URL.<init>(URL.java:593) at java.net.URL.<init>(URL.java:490) at java.net.URL.<init>(URL.java:439) at com.inductiveautomation.ignitionsdk.PostModuleMojo.postModuleToGateway(PostModuleMojo.java:89) ... 24 more [ERROR]
each time I try to install, I get this message.
I haven’t got any trouble to install module with web interface.
Do you know why? I think that I forget something but I don’t know what ?
Any idea?
Best regards
pom.xml (3.59 KB)
I think you need to include “http://” in your gateway address configuration.
Hi Kevin,
thank you for your quick answer but I already did a test with “http://” before the ip.
The console result said :
[INFO] Installing D:\dev\svn\LB9000\LB9000-build\target\LB9000-Driver-Module-unsigned.modl to gateway. [INFO] Deploying to http://127.0.0.1:8088/main/system/DeveloperModuleLoadingServlet [DEBUG] Successfully connected to http://127.0.0.1:8088/main/system/DeveloperModuleLoadingServlet/main/system/DeveloperModuleLoadingServlet [DEBUG] Successfully encoded D:\dev\svn\LB9000\LB9000-build\target\LB9000-Driver-Module-unsigned.modl. [DEBUG] Successfully wrote D:\dev\svn\LB9000\LB9000-build\target\LB9000-Driver-Module-unsigned.modl to Gateway. [INFO] ------------------------------------------------------------------------ [INFO] Reactor Summary: [INFO] [INFO] LB9000 Driver Module ............................... SUCCESS [ 2.125 s] [INFO] LB9000-Gateway ..................................... SUCCESS [ 5.797 s] [INFO] LB9000-build ....................................... FAILURE [ 3.168 s] [INFO] ------------------------------------------------------------------------ [INFO] BUILD FAILURE [INFO] ------------------------------------------------------------------------ [INFO] Total time: 11.459 s [INFO] Finished at: 2017-04-03T22:56:05+02:00 [INFO] Final Memory: 14M/117M [INFO] ------------------------------------------------------------------------ [ERROR] Failed to execute goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.0.8:post (postexecution) on project LB9000-build: Could not post the module to the Gateway. Could not post module to gateway. http://127.0.0.1:8088/main/system/DeveloperModuleLoadingServlet -> [Help 1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.0.8:post (postexecution) on project LB9000-build: Could not post the module to the Gateway. at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80) at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288) at org.apache.maven.cli.MavenCli.main(MavenCli.java:199) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356) at org.codehaus.classworlds.Launcher.main(Launcher.java:47) Caused by: org.apache.maven.plugin.MojoExecutionException: Could not post the module to the Gateway. at com.inductiveautomation.ignitionsdk.PostModuleMojo.execute(PostModuleMojo.java:78) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207) ... 21 more Caused by: org.apache.maven.plugin.MojoExecutionException: Could not post module to gateway. at com.inductiveautomation.ignitionsdk.PostModuleMojo.postModuleToGateway(PostModuleMojo.java:119) at com.inductiveautomation.ignitionsdk.PostModuleMojo.execute(PostModuleMojo.java:75) ... 23 more Caused by: java.io.FileNotFoundException: http://127.0.0.1:8088/main/system/DeveloperModuleLoadingServlet at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1836) at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1441) at com.inductiveautomation.ignitionsdk.PostModuleMojo.postModuleToGateway(PostModuleMojo.java:110) ... 24 more [ERROR]
pom.xml (3.6 KB)
What version of Ignition are you using now?
You may have to modify ignition.conf and set one or both of these flags in the additional parameters section:
-Dignition.allowunsignedmodules=true
-Dia.developer.moduleupload=true
At some point a change was made so that the developer module loading servlet must be explicitly enabled.
Great, it works
:laughing: :laughing: :laughing:
should be written on this page, no?
https://docs.inductiveautomation.com:8443/display/SE/The+Ignition+Maven+Plugin
Thank you :thumb_left:
Best regards
Hi Kevin,
is there any other useful options like theses?
regards,
