Install Ignition Edge Silently in Windows
How can I silently install Ignition Edge on Windows 10? I see in the manual that there is an “Automated Installation on Windows.” But I don’t see any information on how to select it to install the Edge version.
Using version 7.9.13 with the single install file.
I’m working on a bat file I can just run every time I setup a touch PC to be used as an HMI running Edge.
I’ve got it auto installing everything else I need so far (like java) and Edge is the last step.
David
