Installation Ignition Edge on Linux arm / Raspberry Pi
All,
I'm still new to Ignition. I need help with installing Ignition Edge. I'm having a little problem with the following:
coleman@raspberrypi:~/Downloads/IgnitionEdge $ sudo ./ignition.sh install
Detected Linux:
Installing the Ignition-Gateway daemon with systemd...
creating default service file...
Created symlink /etc/systemd/system/multi-user.target.wants/Ignition-Gateway.service → /etc/systemd/system/Ignition-Gateway.service.
coleman@raspberrypi:~/Downloads/IgnitionEdge $ sudo ./ignition.sh start
Starting Ignition-Gateway with systemd...
Job for Ignition-Gateway.service failed because the control process exited with error code.
See "systemctl status Ignition-Gateway.service" and "journalctl -xe" for details.
Failed to start service Ignition-Gateway
Here the wrapper-license.conf
#encoding=UTF-8
wrapper.license.type=DEV
wrapper.license.id=202110090000003
wrapper.license.licensee=Inductive Automation
wrapper.license.group=
wrapper.license.dev_application=Inductive Automation
wrapper.license.features=64bit
wrapper.license.upgrade_term.begin_date=2009-11-06
wrapper.license.upgrade_term.end_date=2022-11-06
wrapper.license.key.1=7a2f-b7a1-7261-ef89
wrapper.license.key.2=2640-d544-0c52-4547
wrapper.license.key.3=2229-b7ad-d7b9-beb6
wrapper.license.key.4=fba8-6503-8ef8-e71e
Anyone know why?
Thanks,
You'll have to show us the contents of the wrapper.log file, not the wrapper license file. When you do, after pasting, highlight everything you pasted and click the "preformatted text" button in the comment editor.
#encoding=UTF-8
When I go into log folder. There are no wrapper logs.
You might need support to look over your shoulder.
