Hi There,
I’m trying to write a script which is made to install Ignition automatically.
I’ve seen that I can run an automated installation by typing the follolwing command:
Ignition-7.x.x-windows-x64-installer.exe --mode unattended --prefix “C:\some folder” --unattendedmodeui none
net start ignition
However, I do not find a way to install my custom java module through the windows command line instead of using the web interface. Is that possible?
Best Regards,
