Trying to install Ignition 7.3.4 over Scientific Linux and I got this:
[code]WARN | wrapper | 2012/02/20 17:11:09 | An encoding declaration is
missing from the top of configuration file:
/usr/local/bin/ignition/wrapper-license.conf
WARN | wrapper | 2012/02/20 17:11:09 | trying the system encoding.
WARN | wrapper | 2012/02/20 17:25:40 | An encoding declaration is
WARN | wrapper | 2012/02/20 17:25:40 | trying the system encoding.
WARN | wrapper | 2012/02/20 17:26:42 | An encoding declaration is
WARN | wrapper | 2012/02/20 17:26:42 | trying the system encoding.
WARN | wrapper | 2012/02/21 08:15:29 | An encoding declaration is
WARN | wrapper | 2012/02/21 08:15:29 | trying the system encoding.
WARN | wrapper | 2012/02/21 08:16:03 | An encoding declaration is
WARN | wrapper | 2012/02/21 08:16:03 | trying the system encoding.
Sadly that's still the state of things. I haven't looked into it further, but the encoding is certainly not missing from the top of the config file and everything still works despite that warning.
The service doesn’t start. The answer trying to start the service is:
te67# ./ignition start
Starting Ignition Gateway...
Waiting for Ignition Gateway..............................
WARNING: Ignition Gateway may have failed to start.
te67#
STATUS | wrapper | 2012/03/14 07:58:48 | --> Wrapper Started as Daemon STATUS | wrapper | 2012/03/14 07:58:48 | Java Service Wrapper Standard Edition 32-bit 3.5.4
STATUS | wrapper | 2012/03/14 07:58:48 | Copyright (C) 1999-2010
Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2012/03/14 07:58:48 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2012/03/14 07:58:48 | Licensed to Inductive
Automation for Ignition Gateway
STATUS | wrapper | 2012/03/14 07:58:48 | STATUS | wrapper | 2012/03/14 07:58:48 | Launching a JVM...
INFO | jvm 1 | 2012/03/14 07:58:48 | WrapperManager: Initializing...
INFO | jvm 1 | 2012/03/14 07:58:48 | WrapperSimpleApp Error: Class
com.inductiveautomation.catapult.Catapult found but could not be
initialized: java.lang.ClassFormatError:
com.inductiveautomation.catapult.Catapult (unrecognized class file version) ERROR | wrapper | 2012/03/14 07:58:50 | JVM exited while loading the application.
STATUS | wrapper | 2012/03/14 07:58:55 | Launching a JVM...
INFO | jvm 2 | 2012/03/14 07:58:55 | WrapperManager: Initializing...
INFO | jvm 2 | 2012/03/14 07:58:55 | WrapperSimpleApp Error: Class
com.inductiveautomation.catapult.Catapult (unrecognized class file version) ERROR | wrapper | 2012/03/14 07:58:56 | JVM exited while loading the application.
STATUS | wrapper | 2012/03/14 07:59:01 | Launching a JVM...
INFO | jvm 3 | 2012/03/14 07:59:01 | WrapperManager: Initializing...
INFO | jvm 3 | 2012/03/14 07:59:01 | WrapperSimpleApp Error: Class
com.inductiveautomation.catapult.Catapult (unrecognized class file version) ERROR | wrapper | 2012/03/14 07:59:03 | JVM exited while loading the application.
STATUS | wrapper | 2012/03/14 07:59:07 | Launching a JVM...
INFO | jvm 4 | 2012/03/14 07:59:07 | WrapperManager: Initializing...
INFO | jvm 4 | 2012/03/14 07:59:07 | WrapperSimpleApp Error: Class
com.inductiveautomation.catapult.Catapult (unrecognized class file version) ERROR | wrapper | 2012/03/14 07:59:09 | JVM exited while loading the application.
STATUS | wrapper | 2012/03/14 07:59:14 | Launching a JVM...
INFO | jvm 5 | 2012/03/14 07:59:14 | WrapperManager: Initializing...
INFO | jvm 5 | 2012/03/14 07:59:14 | WrapperSimpleApp Error: Class
com.inductiveautomation.catapult.Catapult (unrecognized class file version) ERROR | wrapper | 2012/03/14 07:59:15 | JVM exited while loading the application.
FATAL | wrapper | 2012/03/14 07:59:15 | There were 5 failed launches in a row, each lasting less than 300 seconds. Giving up.
FATAL | wrapper | 2012/03/14 07:59:15 | There may be a configuration
problem: please check the logs.
STATUS | wrapper | 2012/03/14 07:59:16 | <-- Wrapper Stopped
com.inductiveautomation.catapult.Catapult (unrecognized class file version) ERROR | wrapper | 2012/03/14 07:59:09 | JVM exited while loading the application.[/quote]
Strange, I have never seen that error message before. Some more questions:
Was Ignition installed from the binary .run file, or unzipped from a zip file?
Which Linux distro are you using?
Which JVM/version are you using? (Sun Java 6, OpenJDK 6, etc)
Did you change the install location from /usr/local/bin/ignition? (if installing from the .run file)
My first thought would be to try uninstalling and installing again. If that still doesn’t work, it might be best to call in to IA support so we can do a Goto meeting and take a look at your box setup.
