could you try something for me? I’ve seen this before for specific graphics drivers which don’t play nice with javafx. could you close the installer program and run it from the command line with the -Dprism.order=sw argument added?
@jcoffman
Thanks, that did the trick, it does make the installation go through command line though. But it did allow me to proceed to install
@jcoffman
Does this work for Linux. I tried to add it to the cmd line:
sudo chmod +x ignition-8.1.1-linux-x64-installer.run -Dprism.order=sw
but that gives an error. my linux screen does nothing if I enter just sudo chmod +x ignition-8.1.1-linux-x64-installer.run
