I have a virtual machine created in HyperV, running Windows Server 2019. The server that is running the VM also has an Ignition Gateway (8.0.12) installed.
I successfully installed Ignition 8.0.14 on the VM running Server 2019, but when the installer goes to start the Gateway, I get the following error:
Gateway Startup Issue
Unable to install the Gateway service
The logs have just the following error:
Logs say: STATUS | wrapperm | 2020/07/08 06:19:17 | The Ignition Gateway Service is not installed.
Is it possible that the gateway running on my physical server is conflicting with the gateway running in the VM?
