Hello, community.
Previously I've shared news about Ignition via Homebrew for macOS, and today I'd like to announce Ignition for Linux via Homebrew.
Why Homebrew?
Because this all started when I was running macOS on my now ten-year old MacBook Air, and since I switched to Ubuntu 22.10 I had a way to tweak and test Ignition via my Homebrew Tap (coatl-dev/coatl-dev).
To learn more about Homebrew for Linux, visit the official site.
How do I install Ignition on Linux via Homebrew?
As easy as
Install Homebrew
/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)" -
Tap
coatl-devbrew tap coatl-dev/coatl-dev -
Install
ignition$ brew install ignition ==> Fetching coatl-dev/coatl-dev/ignition ==> Downloading https://files.inductiveautomation.com/release/ia/8.1.22/20221101-1006/Ignition-linux-x86-64-8.1.22.zip ######################################################################## 100.0% ==> Installing ignition from coatl-dev/coatl-dev ==> /home/linuxbrew/.linuxbrew/Cellar/ignition/8.1.22/bin/ignition checkruntimes ==> /home/linuxbrew/.linuxbrew/Cellar/ignition/8.1.22/bin/ignition runupgrader ==> Caveats The data and logs folders have been symlinked to: data: /home/linuxbrew/.linuxbrew/etc/ignition logs: /home/linuxbrew/.linuxbrew/var/ignition ==> Summary 🍺 /home/linuxbrew/.linuxbrew/Cellar/ignition/8.1.22: 1,414 files, 1.5GB, built in 36 seconds ==> Running `brew cleanup ignition`... Disable this behaviour by setting HOMEBREW_NO_INSTALL_CLEANUP. Hide these hints with HOMEBREW_NO_ENV_HINTS (see `man brew`). -
Start
ignition$ ignition start Starting Ignition-Gateway... Waiting for Ignition-Gateway...... running: PID:157428 -
Open your browser and go to
http://localhost:8088and provision your Gateway
Updating ignition on Linux via Homebrew
Usually when Inductive Automation releases a new version for Ignition I make the changes to the Formula and have it ready the same day or within a day, but if I'm not quick enough feel free to create a Pull Request.
But this is what I recommend:
- Run
brew update && brew outdated - If there's an update for
ignition, runignition stop - Then
brew upgrade ignition - Finally,
ignition start
You can also pin your ignition by running brew pin ignition, and unpin it whenever you're ready to upgrade.
$ brew pin ignition
$ brew list --pinned
ignition
Final comments
Thanks for reading.
