Installing Unsigned Module: Exception Parsing module.xml
Built a module successfully, but when trying to install on the gateway I have gotten the error: Exception parsing “module.xml”. In the logs I’m getting ‘Caused by java.lang.IllegalArgumentException: Invalid version: “RWS”’
Here’s the full message:
java.lang.Exception: Exception parsing "module.xml"
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.parseModuleInfo(ModuleManagerImpl.java:1704)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.extractModuleInfo(ModuleManagerImpl.java:1697)
at com.inductiveautomation.ignition.gateway.web.pages.config.ModuleInstallPage.eulaCertCheck(ModuleInstallPage.java:120)
at com.inductiveautomation.ignition.gateway.web.pages.config.ModuleInstallPage$1.onSubmitInternal(ModuleInstallPage.java:71)
at com.inductiveautomation.ignition.gateway.web.components.CsrfPreventingForm.onSubmit(CsrfPreventingForm.java:67)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1310)
at org.apache.wicket.markup.html.form.Form.process(Form.java:967)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:789)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:701)
at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:216)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:243)
at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:236)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:890)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:261)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:218)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:289)
at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:259)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:201)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:282)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:201)
at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1601)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:116)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
Caused by: java.lang.IllegalArgumentException: Invalid version: "RWS"
at com.inductiveautomation.ignition.common.model.Version.(Version.java:93)
at com.inductiveautomation.ignition.common.model.Version.parse(Version.java:252)
at com.inductiveautomation.ignition.common.modules.ModuleInfoParser.endElement(ModuleInfoParser.java:138)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.common.modules.ModuleInfoParser.fromXML(ModuleInfoParser.java:242)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.parseModuleInfo(ModuleManagerImpl.java:1702)
... 63 common frames omitted
I find it odd that the version is being shown as my description. But don’t know what to do with this information. Any help explaining this would be appreciated.
Can you post your actual module.xml file?
Are you using one of our plugins (Maven, Gradle) to generate it? Can you post a snippet of how you have the plugin configured in your build file?
 <moduleDescription>${project.description}</moduleDescription>
 <moduleVersion>${project.description}</moduleVersion>
This was my problem. Doy!
Hah, yep, that’ll do it :slight_smile:
