I'm new to perspective and was wondering what would be the best way to create a "template" similarly to what I'm used to do on vision.
The Idea is to have a view with the tag path passing the params to the embedded views as below:
By linking the objects in the embedded vies to the UDT, I thought that I could change the child views easily but I'm stuck in that topic. Any ideas?
There are a variety of ways of achieving what you want and someone will probably suggest some. Meanwhile, a very simple approach is to use the left border of the label as the indicator.
Properties for the 24 VDC indicator.
Just put a binding on style.borderColor to change to indicator status.
I'm not sure I understand what the issue is, can you explain where you're stuck ?
It sounds like maybe you should be taking advantage of the Flex Repeater.
