In a dynamic property I have a value which is an Integer value. What I would like to be able to do is take another dynamic proper which is a String value and have it equal the Integer value but be 2 digits in length.
So if the Integer Value is = 1 then the string Value would be 01, if the Integer Value is 23 then the string value would be 23.
I though that this was what the ‘NUMBERFORMAT’ command was for but it does not make the string 2 digits.
This is the code that I tried:
numberFormat({Root Container.value1},’##’) - [this code is equal to value2 which is a dynamic property which is set to string.]
value1 is a dynamic property which is set to Integer.
