Integrating AI for data analysis
Good evening,
to do some testing, I implemented a call from a view to Gemini.
Specifically, I added a table in a view with default values (population data, cities, etc.), and through a textbox I ask Gemini for information, passing the table as the data source. Gemini’s response is then displayed in a markdown component.
So far everything works correctly, but it’s clear that this opens up a lot of possibilities in terms of what can be analyzed and how the response can be obtained, for example in tabular format or as a chart.
I was wondering if anyone else has already tested something similar and, if so, whether they have any advice on how to approach this in the best way.
Thanks.
Good morning Aiasa21,
I'm currently battling with IT to get approval to use Gemini. It's the usual problem: organizational data. They are digging their heels in on that, while we miss a huge opportunity to analyze data like never before.
I have run a lot of tests; I think the most relevant ones involved passing results from Named Queries—pulling information from our MES and GMAO (Maintenance data) for a full week— to identify improvement opportunities. It still has some room for growth, but it saves us all the work of documentation, selection, and resource allocation when investigating our top 3 breakdowns
I also use Markdown for the responses. Current LLMs have the capability to build it perfectly on the first try, and it looks visually great.
Thanks. Pablo.
